What is a good operating temperature?
tigerhack
what temperature my engine should not exceed and what is normal ?. i notice mine intend to increase at hi speed .
Haut Medoc
Re: What is a good operating temperature?
That depends on if you are raw water cooled or closed cooled......
160 for raw & 180 for closed.......
Anything over 190 & you definately have a problem......;)​
tigerhack
my gauge dont even budge when it is idling ,only at hi speed it intend to go up more ...so should it be the reverse in this case ?
Haut Medoc
Budge from what?..... :confused:​
AZSenza
From what I remember from previous engines, it sounds like your thermostat has been removed. the engine may have been over heating and a previous owner removed it. I would start by replacing the impeller (Pretty Cheap and Easy) see where that leads, if no change, replace the thermostat (Also cheap but not quite as easy)
Mkos1980
I have a 140 stat and after a hard run and an idle down it'll go to 150. After that at idle or taking back off It'll drop to 140ish. Raw water cooled here.
Haut Medoc
Perfectly normal....;)
Ayuh,......
That's exactly what TigerHack's Should be doing.......
