I have a 59 johnson 5.5 and while I have replaced the impeller, and I know that it's in right and pumping up water, it's not cooling and water doesn't come out the exhaust. I run water through both holes in the thermostat chamber - so that water goes through the head and out the exhaust and the other way down the leg and out the water inlet area. So it seems the passages are clear. It seems the only time I can get it to work is when I remove the water inlet plate, and shoot water into the access hole with the hose. Any advise would be great, as I am getting tired of having to remove the head every damn time. It seems once water is in the pump housing it works, could I be getting some weird vacume thing going on? By the way the lower unit is totally submerged when I am bucket testing. Could it be the exhaust gasket? Mine is in good shape, but ya never know.
thanks
mc
thanks
mc
