61 lark question
On my 61 lark there is a lever that rides on top of the flywheel that connects to a sorta rocker arm that pushs in and out on a spring loaded valve on top of each cylinder.What does this gizmo do.? I think it is a compression release to make for easy starting. If so can the adjustment of the valve screw affect the compression during a compression check?thanks
tashasdaddy
Re: 61 lark question
it is a compression relief, for when you are rope starting, does not effect electric starting. it is connected to the recoil, not the flywheel.
F_R
It will give false readings if you are trying to do a compression check with the recoil starter. Disable it by removing the stainless steel bar across the top before doing a compression check.
The adjustment screws in the rockers should not contact the valves when recoil is retracted. I forget the clearance specs....015"???
Thanks.This engine is new to me and I dont know WHO has messed with it before so Im trying to explore every thing.
