1992 yamaha 200 outboard
jjdluz
like to know my yamaha outboard 200 does ignition switch can be push in and hold for warm up,i do have choke switch,and i got orange spark come from all 6 cylinder,what is that mean,some part about ready go bad?cdi?stator coil?and i unplug all of the ignition core one at the time,and one core does not effect running,but motor have no problem crank up and run everytime,core and plug have been swap and test is good,thanks for any tips.
Ray Neudecker
Re: 1992 yamaha 200 outboard
If you have the choke switch on the box, then pushing in on the key does nothing. There is a warm up lever on contro; box if using the 703.
What is the problem you are trying to trouble shoot?
jjdluz
just like to know my ignition switch,i realy like to know what i need to check next about my one dead cylinder,unplug ignition core ,motor rpm dint drop,and i did swap the core and plugs test good,is carb?is stator coil?u think i need to check any gas go to that cylinder first?what would u do,thanks for the help.
