Re: Set Me Up!!!!
I'm still confused. OMC rates its motors at a specific rpm, not a range. For example, my motor is rated at 65hp at 5,000 rpm. The rpm range of 4,500 - 5,500 for my motor is specifically described as WOT operating range in the factory maintenance manual.
Here's what the manual has to say about prop selection:
"Selection of the correct propeller is one of the most critical factors in acheiving satisfactory performance of boat and motor. Propellers must be custom selected to match the boat, load or application. (SELECTION OF AN INCORRECT PROPELER CAN CAUSE SERIOUS DAMAGE TO THE MOTOR)"
"Select a propeller that will allow the motor to run at the top limit of its full throttle operating range with the lightest load that the boat will carry. (see Specifications, Section 2, Full Throttle Operating Range.)"
"Remember, if the motor operates below the recommended full throttle RPM range, motor is laboring and power and efficiency are being lost. If the motor operates above the recommended full throttle RPM range, motor speed is excessive and additional power and efficiency are not being gained. In either case, serious engine damage may result."
My concern here is that the advice being given will result in excessive stress and wear on the OP's engine. That said, I'm all ears if someone has some data, resulting from long term testing, that indicates there is some benefit to running the motors faster than OMC recommends.
