Yamajoe
- Oct 31, 2007
- 264
Happy New Year.My 1999 F80, recently developed a tapping noise following a spate of bad fuel in the system. I cleaned the carbs, 4th carb blocked main jets, in boat fuel/water separtor filter was dirty, replaced with new, checked fuel pumps, the diaphram in one of the pumps is stretched, but no obvious tears, refitted these, have ordered kits and will overhaul pump. Compression numbers are #1 = 138, #2= 135, #3 119, #4 =138. Drained oil and installed new oil filter. Motor starts promptly, idles smooth and no smoke, the problem is this tapping sound which starts at idle and occassionally stops for a second or two and keeps on ticking on, it increases in volume when power is applied up to 1000rpm ( i am running the motor in a bucket and will not increase rpm beyond this point).The rectifer/regulator had melted down, it is removed waiting for a replacement to arrive. Looking forward to your help with thanks.
