This is on the AML35D....I thought the plugs had been steam cleaned so I went and bought a new compression gauge today. The motor is in a shop at about 65 degrees, I took out both sparkplugs, gave it full throttle and pulled till the gauge wouldn't go higher. Top cyl. was 100 lbs and bottom was 95 lbs. I don't have 25 hours on this motor since I rebuilt it with new pistons, rings and a brand new block.Unfortunately, I couldn't find my old compression tester before I started break in for a baseline. I was expecting higher compression. I haven't retorqued the head bolts yet. Would you expect any compression with a blown head gasket? Thanks for any info.
