I have a McCulloch 4HP that I am trying to disassemble without ruining anything. It is model - s/n 82090-11-4058. The repair manual says "To overhaul the power head, clamp the motor on a stand or support, remove the lower skirt (shroud): then unbolt and remove the fuel tank . . . ". My problem is the bolts are covered by a plastic strip called a molding assembly part number 80265. The molding assembly is held in place by a metal clip at each end and a strip that fits between the shroud and gas tank. I have unhooked the clips but I can't seem to pull the molding assembly from between tank and shroud without tearing it and deforming the molding. I would like the molding to look good when I put it back. Any help would be appreciated.
