buckeye_sean
Thread starter- Joined
- Jun 2, 2004
- 129
This may seem absurdly silly to some - just thought I'd ask before I do something I'd regret.
My 17' Fisher Deep-V has a 30 gallon internal tank which runs my 90hp Merc. oil-injected 2-stroke. I always carried along a 6 gallon tank with mixed fuel for my 2-stroke kicker - it was not injected. I just replaced the 2-stroke with a Merc. 4-stroke 9.9. I want to run both the 90hp and the 9.9 off of the internal tank.
Do I...
1. Manually switch the 1 fuel line between the motors as needed?
(Seems there is a better way to do this.)
2. Split the fuel line with some kind of "Y" fitting? If yes, do I need a primer bulb on each end? Also, is there any harm in running a 2-stroke and a 4-stroke off the same fuel source? I have an in-line glass fuel filter on the fuel line and I have seen the 2-stroke oil tends to "back-feed" a little bit into the filter.
Again, sorry if this sounds silly - just never done it before.
Do I...
