erikgreen
Thread starter- Joined
- Jan 8, 2007
- 3,105
I drained the lube from my secondary (my extra) sterndrive today, to see what work would be needed to replace the seals on the drive. There was no water in the drive lube, thankfully, and the Ujoint and splines seem in good shape.
The gears inside looked useable (no chips or worn spots) but when I counted the teeth of the gears under the top cap, I found that the gear on the input shaft had 24 teeth, and the gear it drove on the vertical (drive?) shaft had 20 teeth. Am I right in reading that this gear ratio means it's a 1.98 to 1 ratio drive?
I got it off an older boat that had a V-8 engine, but I doubt the PO who worked on it would have had any clue about drive ratios, so he may have just run it with the wrong drive.
I was hoping to replace the seals in this one and use it instead of my primary sterndrive, which was damaged in a car accident.
Secondary question - am I right that swapping those gears out from the 1.5:1 drive to this one would require specialized tools and is hard to get right?
Erik
Erik
