Re: Flourescent lights and gelcoat?
While all fluorescent lamps produce UV light, all standard lighting lamps have the UV impinge on a fluorescent coating (hence the name fluorescent light) which fluoresces (wow, can I spell redundant?) producing visible light. The process is very efficient and very little to no UV is lost through the glass tube --UV does not penetrate most glass. That's why you don't get tanned indoors or through car windows. SO, No, Fluorescent lamps are not bad for the gelcoat. --even if you leave them on for 24-7. Think about the boats sitting inside the showrooms.
Just for info, Simply put, UV is short wave, high energy light. That's why it damages gelcoat, and unprotected fiberglass even faster. The energy breaks down the bonds and cross linking of the cured styrene. Visible light is long wave low energy. IR is even longer wave and although we use it for heating, it is lower in energy than visible light.
The main danger in these lamps is when they break, the phosphor coating is toxic, as is the mercury they use to produce UV
