Tao of Funk
Thread starter- Joined
- Nov 8, 2007
- 58
I performed a stator test as follows:
1. Disconnected positive battery cable
2. Disconnected stator leads
3. Connected an ohmmeter between the (yellow) wires
The meter read infinity. The manual stated I should get a reading of 0.75 ohms +/- 0.2ohms (9 amp system). The windings are therefore open and I should replace the stator. I'll order one today as long as someone can verify these results (Hightrim, Tashasdaddy, F_R, Joe Reeves you guys have been right evey time I have asked questions before). I don't understand why the last time I ran the boat the rectifier felt hot. I tested the voltage at the battery with the engine running and after I turned it off and there was no difference (12.3 volts both times).
Thanks guys iboats forums rock!
GB
GB
