Accessory Switch Connections
cindalyn
OK, I got lots of good help regarding my NAV and anchor light problem.
Now my question is what should PROPERLY be attached to the Accessory switch? I only have one.
I have a bilge pump switch and that is connected to the bilge pump.
Should the VHS radio, GPS, Compass light be attached to the accessory switch? The Accessory switch goes through a breaker. Should each individual piece of equipment be protected with a fuse/breaker or is the one sufficient?
jtexas
Re: Accessory Switch Connections
I wouldn't use my last remaining switch for appliances that have on/off switches (radio, gps). are your fuses integrated into your switch panel? if you don't have any more available fuses, you could run a 12V wire direct to each (connect to the switch panel 12V would be fine) either with in-line fuse holders, or else you could add a small plain fuse block.
I'd consider using that switch for a 12V power outlet (cigar lighter), or maybe courtesy lights, something like that. my compass is lit on the same circuit as the instrument panel lighting.
tashasdaddy
go to the marine store, buy a switch panel, and fuse block and expand the system.
this will help.
