BigNiner19
Thread starter- Joined
- Jul 1, 2006
- 234
Re: Johnson 60 Help!
Silvertip,
Did you not see the pictures? The middle piston blew. Lower unit seems fine. I actually was able to clean out a lot of the debris inside the crankcase and was able to get the flywheel to spin. But I believe I am going to buy a rebuild kit for my motor from a guy on ebay who has pretty good feedback....
I just need to figure out which of the two kits to get for my motor as it probably would make a huge difference in what would work, and what would not work...and not knowing the exact model of my motor...this can get quite challenging.
Cory
Drop the lower unit and spin the engine. If still binds it's an internal problem (broken ring, piston skirt, rod, etc). If is free, then there is a lower unit problem.
Silvertip,
Cory
