Spark plug question for 175 Johnson
JJB
I have a question about which plug to use . The manual said to use Ql-78yc but for oil injected to use QL77jc4 . The bombard site list the QL -77jc4 as a optional plug . What is the difference in the plugs and what would you guys run in a 2000 175 johnson . Thanks for the input
angus63
Re: Spark plug question for 175 Johnson
I use ql78yc in my 95 175 opro. Ql77jc4 run a bit cooler. Either will work fine as long as motor is not modified, wot timing is correct, carbs are clean, fuel is fresh 87 octane, and oil is tcwIII. I originally had 77's when I got the motor, but changed to 78's when OMC changed recommendations. No change in performance or economy.
Good luck
Dhadley
As mentioned the 77's are a bit cooler which I like. The Y in the 78's means extended reach. Personally I'm not a fan of them in that motor in recreational use.
