Hello all...I'm new to this forum so please forgive me if I'm not following protocol. I'll get right to the point. I own a 1990 115hp Evinrude mounted on a 1978 17" Mako. Was out this past saturday doing some fishing at a favorite spot and when I went to leave I started from an idle and went WOT to get on a plane, got between 5000-5500 rpms and traveled 50-75 yards and the engine immediately dropped back to around 2000 rpms and ran on the rough side....did this on and off the entire trip back. Took forever to come in. I'm thinking a fuel starvation problem such as a faulty fuel pump. The VRO has been disconnected some time ago and I now pre-mix. Went out this am and checked for spark at each cylinder with a spark gap tester and appears OK. The carbs were rebuilt about 2 months ago and I have had it out since then and everything seemed fine. It will start fine and idle OK. I just started it up a few minutes ago and while idling I pulled each plug wire off one at a time and found that cylinders 1 & 2 made a noticable difference in rpm drop while 3 & 4 only made a slight difference...changing the plugs did not seem to make a difference. Kind of at a loss here on what to try next and am hoping someone will be able to help, Thanks in advance.....
