Re: New guy!
Congrat's on your find.
Th information above is good.
I would do this:
1. Buy a manual.
2. Buy a manual.
3. Change the lower unit lube. Remember to change the fill/drain plug seals.
4. Change the water pump impeller. Sitting makes them take a "set" and they lose efficiency.
5. Run Sea Foam (NAPA) through the fuel system, on a regular basis.
6. Use a good quality TCW-3 rated outboard oil, mixed at 50:1 (one pint to six gallons).
I will warn you now. Having the engine sit for that long could have gummed up your carburetors. They may be OK but if the engine does not run smooth or lacks power, shut it down immediately and service the carbs. Remember, the oil and fuel are needed to lubricate the engine. If a carb is stopped up, that cylinder gets NO lube.
If it were me, I'd rebiuld them anyway. Cheap insurance.
