I have had my 1988 Mariner 150 in the shop for trouble shooting, intermittent alarm. They have come to the conclusion that there is an oil sending gear that works off the crank shaft that has stripped and does not work the oil pump. They indicate it can cost from 200.00 to 2500.00 depending on what else they found. They also mentioned that I would be okay to simply do premix into the gas tank and things should be fine. I know this is not the best thing to do, but would it suffice for a little while until I can come up with the additional funds and if so, what is the mixing ratio to mix in the tank?
Thanks in advance of any assistance.
