A little history on my 1977 55hp Johnson first...
Items replaced with new (in order):
Starter Solenoid
LU oil changed
Spark plugs
Ignition switch
Rectifier
NEW, not replacead, Tach
Carb kit
***And 1 coil, so far***
Before I replaced the coil it would do 5500rpm @ WOT until it ran hot, then only run 3000rpm at WOT. I replaced 1 coil, as the spark plugs were indicating only one was the problem.
After the new coil, the next time on the water it ran 5500rpm WOT for 15 +/-minutes, that was the amount of time it took to get to our destination for fishing. Absolutly no signs of problems at this time. On the way back to the ramp the same problems as before were happening.
I am going to replace the other coil, since it is only $40 and as old as the other replaced coil, as I think it might be my problem.
What do you guys think?
Starter Solenoid
LU oil changed
Spark plugs
Ignition switch
Rectifier
Carb kit
