ziggy
Thread starter- Joined
- Jun 30, 2004
- 7,473
regaurding the upper. i'm gonna replace the bearings in my 1 drive for the drive shaft. the ones on my drive gear yoke. i understand that i will have to shim the drive gear. question to me is. will i need to shim the upper drive shaft? do i need to check the rolling torque of the upper drive shaft (driven gear)? or can i assume that it is set up proper? i will be useing the old gears, both driven and drive, as they seem to be servicable. replaceing the brgs because they're blue and the blue wont come off. i understand that if there's a question about a brg. any question. it should be replaced. that's why i'm doing the brgs.
in my previous posts, folks have talked about rolling torque on the drive gear too. setting the bearings proper. i have the small spacer in my drive and have ordered new spacers to go along with the new brgs. i just want to confirm. i don't do rolling torque on them when useing the spacers? is that right. just torque it down to 85 ft lbs while turning the brgs?
previous post over this same matter.....
http://forums.iboats.com/showthread.php?t=228998
http://forums.iboats.com/showthread.php?t=229200
i'm having to much time on my hands while parts are on order......thinking of possible questions. and the 2 questions above are naggin at me..... mostly the one about the upper drive shaft (driven gear) rolling torque. basicly i ain't gonna do nothing to that shaft is my notion... is my notion outa line?
