in water engine flush
Shaun78
I am going to leave my boat in a slip but I want to flush out the salt water. Is there an easy way to do it thats easy on the wallet? How & where can I get it?
JustJason
Re: in water engine flush
rig a t fitting after the raw water pump. should be able to get one at home depot
crazy charlie
all you need is a pair of ear muffs.Reach down to your fully trailered drive and slip on the muffs with water at full pressure and run the motor .Make sure to have the water running before you start the motor and make sure you shut the motor before you shut the water.Thats what I do every time I use my boat.Very easy on the wallet.Takes a small amount of effort.Charlie
Shaun78
put the muffs on while the boat is in the water?
Ayuh,........ Why Not,..??.... That's the Cheap'n Easy way..........
Otherwise,...... You'll have to splice it a "T",+ valves into the in-coming water line to control the flow of Salt,+ Freshwater.......
Shaun78
My drive doesn't come up to far. It might be hard to reach w/out jumping in the water
Ayuh,.........
You asked for the Easy way out,.......
I guess you get the Choice of either doing some Plumbing,......
Or,.......
Going Swimming..............
bruceb58
One option is the Perko Flushpro. It fits in the line between your outdrive and the raw water pump and closes off the salt water path while the hose is turned on.
Another option is the Volvo Neutra-Salt system which injects a solution when you shut down to neutralize the salt.
Shaun78
What size do I need? Does it hook up to one of the 2 hoses that hookup to the raw water impeller housing? Thats a heavy duty hose. Can you just splice it in with 2 clamps?
Shaun78
Is the perko sytem reliable? I would hate for it to fail and block the water from coming in. Most people w/merc engines in slips. Do you flush them or not? Salt Water
