recoil starter
bubba695
Just reroped and rewound recoil sarter spring but now the three coggs that grab the flywheel don't come out like they are supposed to do. Can anyone fill me in on what I might have done. Everything is as it was when I took it apart.
Thanks
wilde1j
Re: recoil starter
Look at parts list on BRP's website. BTW, you haven't told us what motor!
F_R
Re: recoil starter
OK, you probably don't have the equalizer cup/spring/spindle assembled properly.
The equalizer cup is the piece that the pawl springs hook to. Inside that is a coil spring. Place the cup on the spindle and get all the coils of the spring up on the step of the hub before inserting it into the pulley.
You DO have the 3 little springs on the pawls, right?
samo_ott
Re: recoil starter
I had problems with the 3 little pawls on my '57 35hp also. They're tough to get working. I like the later models with the single pawl a lot better... easy to fix and work on. My '58 10hp has the single so maybe they changed in '58...
F_R
Re: recoil starter
A picture is worth...something
The equalizer assembly
Also, notice the locating pin that must be aligned with hole in housing.
bubba695
Re: recoil starter
Thanks for the info and the pic. works perfect now.
MrGED05
Re: recoil starter
If anyone is still following this thread, I would love to hear the trick to connecting the main recoil starter spring to both the housing and the bottom of the recoil starter mechanism.
Thanks in advance,
Gary
