Having problem with shift cable. Help Please
tigerhack
My shift Cable Keep rubbing on my drive couplin , could someone tell me the best place to run it, it work fine when i did have in the triangle couplin , i dont want to take the engine out back just for that, have anyone have experience this before , is there a work around ?
BAYLINER185
Re: Having problem with shift cable. Help Please
If need be just use a zip tie with a scew hole so you can screw it securly to the transom or evenuse annother zip tie through the hole and zip tie it back tosomethign to keep it fromm rubbing on the drive coupler.
On my 185 BAYLINER the cables are secured up out of the way with cable ties. Simple easy fix!
