Re: Regarding the correct gear case lube
Well, I decided to get Lucas High Performance Heavy Duty SAE 80w-90 Gear Oil. It says "Excellent for use in outboard final drives." Not cheap, but since I live 45 minutes away from the nearest West Marine store (and don't normally go that direction) I decided to simply buy from Advance Auto. I should think it would do fine, but, if there's an expert that says absolutely "not good" I guess I'll reconsider.
Jack
