3hp evinrude won't run unless chocked???
kaashlock
I have a 1952 3hp evinrude lighttwin. I rebuilt the carb. It will run only if it's about half choke. If you try to idle down it will die. I have the slow speed at 1 1/2 turns from close and high speed at 3/8 from close. Any suggestions. on how to get it to run without the choke out?
Thanks,
Kenny
F_R
Re: 3hp evinrude won't run unless chocked???
Try opening that high speed some and see what happens. 3/8 doesn't sound like enough.
Will it keep running as long as you have the choke pulled out? If not, you could have a clogged filter in the tank.
I hate to keep preaching this (no I don't) but are you sure the ignition is OK? Bad coils are famous for fooling a guy into "fixing" the carb.
steelespike
Mixture screw settings are a starting point you need to adjust them to the best setting.Be sure to leave the high speed just a tiny bit on the rich side.
Most likely you need to do the carb again and prove that all passages and jets are clear.Be sure float level is set right.
BillP
Sounds like fuel starvation to me. Your motor may or may not have a tank filter (actually a screen). I have a Johnson jw10 (1953) that doesn't but had two later versions that did and the screens came out by unscrewing the external tank fitting. Except for cowl these are the same as Evinrude 3s. There's not much mystery on these simple engines and carbs. 3/8 out might be a tad lean for the high speed needle. I would back it out more...initial settings for it are 1/2 to 3/4 out...and the high speed needle has to be dialed in before doing the low speed (low speed settings start at 1 to 1-1/2 out).
Other situations that happen...needle valve sticking, float height wrong or the nozzle gasket leaking air. The carb bowl can be dropped off these without removing the carb so checking this stuff is fast and easy...but a few light raps on the carb with a mallet while the engine is running will sometimes release stuck floats and needle valves. There's a tiny pocket in the bowl at the tip of the high speed needle that gathers trash easily and blocks gas flow. I've "field" cleared this area by taking the needle out and letting fuel flow out a few minutes to purge it. Whatever the problem is I don't think it's major.
You did unscrew the tank vent and make sure it's clear, right?
samo_ott
Fuel starvation... Something was probably missed in the carbs... Did you clean behind all the welsh plugs?
