Re: Adding a second battery
No isolator needed. Yes, the switch does need to be "make before break" but I've not seen any recently that aren't. In the BOTH setting the batteries are wired in PARALLEL hence making one big battery out of two smaller ones. The real issue here (and it is apparent in this series of posts) is that people want this switching capability but they don't have a clue what the switch is for or how to use it. In very simple terms, the switch provides you with the ability to 1) turn off the entire electrical system (as in the OFF position). 2) Run all accessories and start the engine from BAT 1 (as in BAT 1 setting). 3) Run all accessories and start the engine off BAT 2 (as in BAT 2 setting). Or 4) Run all accessories and start the engine from BOTH batteries (as in BOTH setting). You don't need to change the wiring of your accessories as long as the electrical system is fed from the COM (common) terminal. You therefore can run everything from BAT 1, BAT 2 or BOTH so you have total flexibility. As I said, if you want to be sure you have a good start battery after being anchored and listening to a high powered stereo system, switch to BAT 2 and run the equipment from the deep cycle. When you get ready to leave, BAT 1 will still be fresh as a daisy. Switch to BAT 1, start the engine and go. Switch to BOTH to charge both batteries. If you happen to run down BAT 2 pretty far, switch to BAT 2 when underway so it gets topped of quickly -- and a 10 minute run back to the dock won't do that so make sure you use a charger to make sure the deep cycle is fully recharged as soon as possible. If you happen to be cruising and notice that the Voltmeter is showing less than 13V (as in the alternator took a dump) you are now running on battery power alone so you could switch to BAT 1 (or BAT 2) until it got low enough that the engine began missing, and then switch to the other battery to get the rest of the way home. Lot's of options with the switch. You just need to understand how to use it. And adding an isolator (essentially a big diode) which allows current to flow in only one direction to each battery would mean you would not be able to draw anything from either battery. Or if you turned the diode around you could not charge either battery. Believe me guys, an isolator is not needed.
