FORUM RULES UPDATED - The forum rules have been updated to continue to provide a friendly and safe environment for our member community. Please take a moment to review the updated rules and our terms of use and privacy policy. Click here for Forum Rules which has links to the 'terms of use' and 'privacy policy'.
Hi....was wondering i want to disconnect batt for less weight and just pullstart boat . where do i modify wires to stop motor, i would like to run them to hand controls for a safty. splice coil wires?
To remove the boat harness for a kill switch you would have to ground and another to the salmon wire to the switch box in the kill switch in the circuit. You also need to remove the 2 yellow wires from the rectifier and tape them off
Actually, I don't think there is a salmon wire in the mercury harness. Black with yellow trace is the magneto ground (kill if grounded) and tan is the temp gauge sender wire.
I see salmon wire coming out of switch box in this link i'm posting .mines a 1976 il check tomarrow . I splice the salmon wire? just scared to short anything.thx
