PINESOL
Thread starter- Joined
- Oct 19, 2007
- 99
well i had a chance to put some time in on the boat ... to no availe .. she doesnt start .. i put new fuel filters in and new gas , nothing .. so i rebuilt the carb didnt find anything that bad other than a ton of silicone on the base gasket ... straight edge checked the manifold .. its perfect , the carb base .. no problems . appeared to be just a temporary fix ... put it all back together .. still nothing ...so i cleaned up the new points and started checking spark again ...i put a new set of ngk plugs in just to make sure , still nothing . i messed with the timing several different ways , still nothing .. any other ideas ... im thinking new coil .. due to the fact it died when the boat was warmed up and cruisen ... but i do get some spark from the wires when grounded .. could this be due to the hot leads not getting a good enough connection at the battery ? also with the key on i do get a little zap from the point contact .. when it tries to start it back fires from exh. and carb depending on where i have the timing set .. any help ... all tune up stuff is new ..
