VacuFlush Question
Locke
Here's a question I never thought I would have to ask. I am looking at buying a 2000 Sea Ray 270 Sundancer that is in great shape except the Vacuflush head doesn't work and the owner believes one of his passengers disposed of a tampon down the bowl. The dealer says this is about a $500.00 item to fix normally and I'm wondering if it's something a mechaniclly inclined owner (me) could handle or would it be the best $500.00 I could ever spend? Anybody have any Vacuflush overhaul experience?
Locke
tashasdaddy
Re: VacuFlush Question
this may help you, it's about the head, and links to mainainance parts.
"http://www.formulaboats.com/145.aspx"
Locke
Thanks for the article but I didn't see any links. I wish the previous owner had schooled his passengers on the do's and don'ts
pgdignan
Couldn't you replace the vacuum flush with a more simple head for less $$? or is the vacuum flush something you really wanted. Personally, when it comes to the potty, simpler is usually way better.
stevens
Well, without ever having seen such a toilet myself other than on the internet, the Vacuflush system seems like a very straight-forward system. See: http://www.dometicsanitation.com/vfdemo.asp
If the system is clogged so that it won't flush, that would mean that you'd have to unhook the discharge pipe from the toilet to the vacum-generator and remove any obstructions. If that doesn't solve the problem, the obstruction may be in the vacum-generator itself, which is supposedly easy to replace.
So, even if mechanically probably fairly straight forward, it could be a messy affair - as with any clogged toilet.
