fireicyhott
Thread starter- Joined
- Jul 30, 2007
- 43
Well just when I got my 1990 Four Winns 225 Sundowner with 5.8L OMC/Cobra running good this happens.
I have had the boat out several times in the last 2 weeks since I got the points issue corrected. One time in about 8 outings the temp gauge spiked up and I shut the engine off for a bit and then everything was fine.
Well today I was out and the temp gauge was at 150-175 for the whole afternoon (1.5 hrs of start and stop). Then I noticed during a 5 min run of WOT the gauge spiked up to 230 F or so. I shut it down to let it cool.
Well I was sitting there watching the engine while it cooled, making gurling noises from the water being so hot. Then all of a sudden it is as if it BELCHED a big bubble, the motor actually moved. I was like oh ****. I had a bad feeling I had water in the cylinders.
I tried to turn over the motor and it wouldn't budge. Yep, water in cylinders. I proceeded to spend the next hour pulling all 8 plugs, turning motor over to clear pistons of water, and then reinstalling plugs. It fired up and I went to dock. Some questions:
1. Why did it overheat? I have removed and inspected impeller in last 3 weeks, everything looked fine and while running it with muffs it sucks water in and spits it out like it should.
2. Should I go ahead and replace thermostat?
3. What was that belch noise and how does water actually get into combustion chambers?
4. Do I have to change the motor oil now that there is probably water in it?
5. Does anyone know of an easier way or different tool to use to pull those damn plugs? I use a spark plug socket and a 19mm open end wrench as you can't get a socket wrench on it due to angle.
Frustrating weekend as my well went out yesterday too! Hell I am afraid to get off the couch now!
Thanks,
Jeff
Thanks,
Jeff
