I have a 1988 60 HP. Where is the overheat warning horn on this motor? How do I check that it works? I ask because the control box that was installed with this motor is from the 1970s and does not have a horn in it.
Thanks
Thanks
Just to add to HighTrims good advice, if the remote control is a 71' or up, it will have a warning horn if equiped with an ignition swith.
Did you notice a tan wire hanging lose in there? That's the lead for the temp sender on the engine.
Remote controls that do nothing more than shift the gears and add throttle will not have a warning horn in them. The over heat warning system takes it power from the ignition switch. That's why I added the Ignition switch in my last post.
Yes, you can add the horn. Does the control have like a padded top?
