johnnyrudeinator
Thread starter- Joined
- Sep 19, 2007
- 14
I picked up a new stator the other day and do not have a manual...I want a "real" manual and they are VERY hard to come by. The question is I read on another post that you could access the stator by pulling the small fine thread bolts and not the large nut holding the flywheel on. Is this true? If so can the stator be changed without removing the flywheel? I was under the impression that you had to remove the flywheel. Is there a way to do this without the flywheel puller?? I have some pullers just not the Merc puller. Thanks for you help. This is an awsome site. Its the reason I didn't make this engine a "black anchor" as I was told to do. It'll push my 330V 40MPH with a 19 pitch prop! Heavy boat.
