Tiller Throttle Cable
banki_21
I did a conversion from remote to tiller on my '92 Evinrude 90hp Jet, and I'm wondering if there is a way to get more movement in the throttle cable? When I hook the cable up it and twist the throttle, I'm still about a quarter inch short on the roller for it to be opened up all the way.
Any help is appreciated.
JUSTINTIME
Re: Tiller Throttle Cable
you should be able to, look at the cable where it goes you should have a nut or 2 to adjust
ondarvr
I have a 98 Evinrude 90hp jet and converted it to a tiller also. I had to make a small aluminum bracket to connect the cable to so it would get full travel, it was very easy. I just bolted it to the plate (pully) the cable connect to. I did 5 or 6 years ago and it's never been a problem.
