Thermostat gasket confusion
5meter
I have a 1983 merc 228.
I bought a new thermostat and gasket set and one gasket is normal (2 bolt holes and a hole in the center for water.) The second gasket is solid with the exception of the bolt holes. I have checked my manuals I can't find any reference to this. Has any one used this?
Re: Thermostat gasket confusion
Ayuh,..................
That's for the Top Cover,..... If your T-Stat Housing Has 1........
Without going to a Parts Manual,....... I don't know Exactly what Your's Looks like.......
5meter
Yes I have a top cover but something doesn't seem wright.
I have two manuals but neither show this.
Do you know of an online manual that might?
bomar76
Wild guess....Seloc and Clymer?
Those are about worthless.....
You want a Merc Factory manual...
5meter
I'm not thrilled with those manuals either, but I thik this gasket may not be for my application.
5meter
Thanks, looks like I ordered the wrong one.
Don S
That sure isn't what it SHOULD be. Time to head to your local Merc dealer and order the right gaskets.
The thermostat is SUPPOSED to be the right one.
