need help repair evinrude 6hp
Always fishing
I just purchased a used 6hp evinrude short shaft. I had it shipped ups to my house it arrived in 3 parts.
The handle that controlls the speed and folds up is completely broken off.
The lever that changes the direction(forward neutral and reverse0 is completely broken off.
My serial # is 662e-e15353.
Can the repairs be done? Approximately how much do you think it will cost?:confused:
By the way what year is this motor? Where can I get my hands on a manual?
Thanks in advance
iwombat
Re: need help repair evinrude 6hp
We'll need a model # to determine year. Should be right where you read the serial#
F_R
Is this question for the purpose of determining repair cost for the insurance co? Anyhoo, the shift handle costs about a hundred bucks new from a dealer, plus an hour to install. Not knowing specifically which part is broken on the tiller, can't tell you the cost of it. It is a significant job to replace the steering bracket if that is broken. I assume you just dropped the 0 from the model/serial and it is a 6602, 1966.
tommays
I could be confuesd BUT i believe you have to pull the powerhead to change the shift lever :eek:
At least you did on the 5.5
Tommays
F_R
Yes, you do have to pull the powerhead. That's the hour labor.
fishermanms
You can get a manual right here at the iboat store.
Always fishing
Thanks
I am trying to get an estimate of what it will cost to fix the motor. I hope to send it off asap.
Thanks for all your help.
