cgrooves
Thread starter- Joined
- Aug 1, 2007
- 57
The background info: 1979 Starcraft with a Mercruiser 898 (305) and a Mercriuser 898 (Pre-Alpha) outdrive.
Symptom: Boat would only shift into forward (going into / out of neutral was fine). It would not shift into reverse (would grind & the RPM's would start increasing).
Treatment: Marine mechanic has replaced the lower shift cable, various linkage parts, tightened everything up at the remote, removed / disassembled the outdrive and looked at the shift cam, gears, etc. The boat will shift into forward & reverse just fine if you do it manually at the outdrive or at the location where the cables all meet (but not via the remote). When they adjust the shifting per the service manual, they can't get reverse. When the play around with the adjustment, they can just barely get forward & reverse, but he said he was afraid it would not perform properly on the water (all work has been done on the muffs). He stated that he has checked the entire shifting system from remote to outdrive and can't find what's causing the problem. Should I possibly have the upper cable replaced? Take it to another mechanic?
