fishermanms
Thread starter- Joined
- Jul 8, 2007
- 100
Re: Will a cotter pin work as a shear pin?
I just went out and removed my propeller. First I pulled the cotter pin. Then I removed the plastic cup that screws onto the shaft that has the hole to line up with the hole for the cotter pin to past thru. Then I pulled my propeler off. My propeller has a part number of 386955 and it is a two bladed 8 X 7. Looking from the back of it there is one what looks to be a brass sleeve that passes thru the center hole of the propeller and extends all the way thru. On the other side, (the side that goes onto the shaft first is a larger brass looking piece that has the notch for the drive pin to rest against and thats it. And that brass piece fits into the propeller and rests against the sleeve. Sorry FR but there is no rubber nothing anywhere in there. Neither is there anything on the shaft all the way to where the propeller meets the lower leg. It all fits snug.. Does not give me reason that I'm missing something.
Fishermanms
Fishermanms
