clunking when accelerating the first time
mrfixitman40
I noticed the first time I take my boat of the trailer it clunks when i go to leave the no wake zone I don't have a pump for the hydraulic tilt but always make sure the latch is connencted before i start the motor is this common or should i be concerned everything feels tight and this is my first boat so some you guys with experiance are probably gonna laugh at some of my stupid ?'s
Thanks for any input
John
Joe Reeves
Re: clunking when accelerating the first time
It could be jumping out of and back into gear BUT since it does it only one time, I dount that this is your problem. More likely that when you lower the engine, it is not completely down and has the locking lever over top of the reverse locking rod..... the rod that goes thru one of those series of holes at the bottom portion of the transom brackets.
It would help if you listed the make, year, and horsepower of the engine.
mrfixitman40
i have a 1964 evinrude v4 75 horsepower is there more than one latch on it that i may be missing? it backs off the trailer and out of the dock with no problem not sure if that helps at all or not
mrfixitman40
ok after this weekend i think you could have been right about about it jumping out of gear this was the first time i ever had it jump out of gear and it did it about 4 times but only at wot and pulling a tube i am going to change the lower unit gear lube i am not sure if it is the right lube for the electric shift because i hadn't changed it since i got it wanted to make sure allk was well but talking to the previous owner i don't think it is right since he says he just got lower unit oil and not the type c (i think that is what it is called) could this cause it to jump out of gear?
Willyclay
First, let me say that Joe Reeves is an "expert" and I am not! However, I did previously own a 1962 Johnson 75HP V4 with electric shift, used it for ten years and performed all the routine maintenance and repairs on it myself. I got to be a good enough outboard mechanic that a local dealer asked me to outsource his excess work during the peak boating season. Given my history, I want to reiterate what Joe Reeves said about the proper lower unit lube with the electric shift unit. That should solve your problem. FYI, I did experience a situation with my motor that could be similar. At the initial application of power in gear, primarily forward, I heard a "clunk". It turned out to be bad rubber motor mounts inside the upper exhaust housing. Under load, the motor was twisting far enough to make contact in the cowling. It required removing the powerhead to replace them. Good luck with your motor and keep us posted on your progress.
mrfixitman40
ok i will have to check the mounts this weekend if it dries out enough to get onto the water for the day and am i right about the type c fluid
Joe Reeves
(Jumping Out Of Gear - Manual Type)
(J. Reeves)
This pertains to lower units on all OMC manual shift outboard engines, or any OMC engine with lower units defined as a Shift Assist or a Hydro Electric Shift unit which incorporates a "Shifter Clutch Dog".
Within the lower unit, splined to the prop shaft is what is most often referred to as a clutch dog, hereafter simply called dog. The dog has at least two lobes protruding from it on both ends, facing both forward and reverse gear. The forward and reverse gears also have lobes built into them near their center area. When the engine is running, in neutral, the gears are spinning constantly via the driveshaft being connected directly to the powerhead crankshaft, but the propeller does not turn due to the fact that the dog is centered between the two gears, and the dog lobes are not touching either of the gear lobes.
When the unit is put into either gear, shift linkages force the dog (and its lobes of course) to engage the lobes of the gear. The lobes of the spinning gear grab the lobes of the dog, and since the dog is splined to the prop shaft, the propeller turns.
The lobes of the dog and gears are precisely machined, most with right angled edges that could be installed in either direction, and some with angles slightly varied that must be installed in one direction only (one end only must face the propeller). Dogs that can be installed in one direction only, if reversed, even if the dog and both gears were new.... would jump out of gear almost immediately. Keep in mind that the lobes are precisely machined with sharp angles!
Due to improper adjustment or worn shift linkages, but usually due to improper slow shifting, those precisely machined sharp edges of the lobes become slightly rounded. Now, with those lobes rounded, as the rpms increase, the pressure of the gear lobes upon the dog lobes increases to a point whereas they are forced apart (jumping out of gear), and due (usually) to the shift cable keeping tension on the engines shift linkages..... the unit is forced back into gear giving one the sensation that the engine has hit something, and the cycle continues.
Some boaters have the mistaken belief that shifting slowly is taking ixt easy on all of the shifting components..... Wrong! Shifting slowly allows those precisely machined sharp edges of the dog and gears to click, clank, bang, slam against each other many times before they are finally forced into alignment with each other..... and this is what rounds those edges off! The proper way to shift is to snap the unit into gear as quickly as possible.
http://stores.ebay.com/Evinrude-Johnson-Outboard-Parts-etc?refid=store
mrfixitman40
Joe with the electric shift is there any way to speed up the shift time it seems to engage quickly and a little rough being you can't back it down all the way to shift .The control is in the start position to shift i am not sure of the rpm yet haven't got the tack hooked up yet if there is a problem i would rather fix it now then to break it worse this was the first time it has ever jump out of gear like it did as soon as i slowed it down to idle it reengaged and away it went but seemed very smooth when it reengaged no bang or grind that i heard thank you again for the advice
Willyclay
Sorry that I failed to answer your question. YES, Type C gear oil is required for your electric shift lower unit! I had the same problem as you when I initially acquired my motor. The previous owner could not get rid of it fast enough. He told me he had hit something underwater. Everything cleared up as soon as I replaced the existing lube with Type C and I never did have to go into the lower unit. Good luck.
Joe Reeves
You didn't mention it previously and I assumed that your engine was a manual shift. I see now that you have an electric shift so disregard the jumping out of gear information above.
Hopefully Willy's info above about changing gearlube eliminates the problem if the unit is indeed jumping out of gear. Otherwise, assuming there is no vltage or broken/chaffed wire problem, you will most likely be faced with replacing the forward hub and spring.
mrfixitman40
thank you joe i am sorry about neglecting the fact of the electric shift i am certainly appreciative of your time and all the others on this forum you guys have alot of info the manual doesn't explain
