timing and adjusting valves changes
delsol
question if you adjust your valves, does it throw of your igintion timing. do you need to reset it..how about you carb mixtures. do they change with valve adjustments as the valves are closing and opening more...
i am running good now . just need to know the answer
bob
bruceb58
Re: timing and adjusting valves changes
Timing and valve adjustment have nothing to do with each other.
By adjusting your valves, you may slightly increase the time the valve is open but not enough to throw off the mixture. The only time you would ever have to compensate for mixture is if you put a different cam in.
delsol
thank you
bob
