uniquesound
- Aug 6, 2007
- 16
i have had a fuel restriction problem and i just got that fixed! Now when i crank the engine it fires right up with the muffs on it when i says fires right up i mean the motor barely makes one rotation and its running, but my prop is spinning and the boats in neutral now the boat will only crank in neutral if you try to crank it in forward it wont start but when i crank it in neutral the props spinning? The engine is a 93 225 oceanrunner counter rotation is this an easy fix? Also on here i found a thread about their engine bumping in forward mine does that to at idle speed it bumps like your barely hitting a little stump but doesn't do it above idle speed don't know if that helps or not!
