MikDee
Banned
Thread starter- Joined
- Jun 6, 2007
- 4,745
89'- 125hp Force, Ok, I've had this motor for about a month now, I've set up the idle screws 1 turn out seems to work fine, compression 120lbs all cylinders, checked the fuel pump valves gaskets diaphram, (all looks good), all the spark plugs seem to be firing good, (normal slightly sooty oily apperance) all the hoses, fuel vents, and filters appear fine. It starts, runs and idles good, but in the lake it stalls as soon as I put it in gear? (very frustrating!), but starts right up immediately (thank god), once I get going, it appears fine, but a little sluggish, it doesn't jump up on plane. WOT is smooth but doesn't seem to be full rpm (non working tach, so I can't tell rpm, or adjust idle rpm) although I keep raising the idle speed screw in the water till it's at a fast idle, but it still stalls? Could there be a problem with the cables hitting the safety shift switch while shifting, causing it to cut out? It's like I turned the key off once I try to shift to forward or reverse? another thing I was thinking about, could I be getting exhaust under the cover, stalling it? I never thought to try it with the cover off on the water? Duh!,,, but, smoke, & water, is coming out fine from the leg, and I don't see anything wrong with the bellows? Between this, problems with the tilt leaking down, trying to diagnose the tach, and problem with the trailer rollers moving out of place, it's driving me nuts! Anyone have any idea's as to why it stalls going into gear?
