what points for 1989 2.3 cobra
bigred01
what auto points will fit my motor. or do thay have to be marine.$ and what about the plugs???
hoof harted
Re: what points for 1989 2.3 cobra
napa can tell you. off my head i can't remember cuz my brain cells are shot. coors does that to you.:confused:
evilratgirl
I have an 88 2.3 cobra. I remember reading somewhere that there was something different on marine points. Brain cell issue here as well. If Iboats dosn't have them, I know boatfix does. Our Napa don't carry sierra parts.
marunr
The points Napa sells for that motor don't exactly fit...I went through that last year. The rubbing block is slightly off and it affects the timing. If you have a dealer close by that sells OMC or Bombadier parts they carry a tune up kit that includes the points, condenser, and rotor.
Recommended plugs are motorcraft AWSF-32 or Champion RS12YC. Gap is .035
Freedom
I have a 1989 2.3 cobra. I had a local marine do a tuneup at the beginning of this season changing the points, condensor and rotor. They started by trying to use Sierra parts and then a couple of other sources, "manunr" is right the aftermarket stuff will not fit. BRP still makes a tuneup kit that fits, I bought mine on ebay (old OMC stock).
martyh
You can get the following parts through any Napa/Sierra parts store, and they should be able to find you spark plugs for it as well.
1987-90 OMC Cobra 2.3
For a Mallory Distributor
Points 18-5314
Condenser 18-5338
Dist. Cap 18-5397
Rotor 18-5404-1
Plug wires 18-8807
For a Prestolite Dist.
Complete kit
18-5283
marunr
Points 18-5314
As I said, they don't work.
Freedom
And I will repeat my agreement, they won't fit.
Don S
Perhaps since ALL your posts mention you drink too much and your brain sells are shot, Maybe, you should just go visit AA and not post till your head clears.......................
martyh
Hmmm, I guess I better call the Napa corporate office and tell them to pull the remaining stock and send out a recall notice for the ones already installed because they don?t fit.
