chuck bartus
- Aug 7, 2007
- 2
I have a 1987 150HP Johnson with a 35 AMP voltage regulator that seems to to putting out over 18 volts at medium RPMs. Can't tell what the RPMs are as the tach is not working also. Before I replace the voltage reg. could someone tell me everything to check? I've checked the voltage at the battery and it matches the gage readings. I've also tightened the battery cables with no change. I have also checked the voltage at the gray wire at the tach and have 9 VDC which tells me the tach is bad. Physically the voltage reg. looks reasonably OK except for a few cracks on top of it. I was thinking of replacing the voltage reg with an aftermaret CDI unit. Any ideas would be helpful. Thanks.
