Steering Cable Problem
LunkerClassic
I'm a new boat owner, so bear with me on the terminology. The rod that goes through the tilt-tube on my outboard will push out when the wheel is turned, but will not pull back in. The cable seems to be moving back and forth fine but whatever linkage there is inside the rod at the end of the steering cable seems to be detached.
Is it possible to just remove the rod portion of the steering system and reconnect that piece. I've removed the rod from the tilt-tube but cannot figure out how to disassemble it any further.....seems sealed pretty tight.
I've attached a picture of what I'm describing....hopefully it works.
Any advice would be appreciated.
Aaron
Re: Steering Cable Problem
The Steering Cable is a Non-servicable item,.......
And,......
You need a New 1......
tashasdaddy
get the number off the black sheath, thats, the replacement.
LunkerClassic
Thanks for the feedback...where's the best place to buy a replacement cable? I plan on doing this myself unless someone suggests otherwise.
Jeffreyi
Lunker:
My rod seems to be frozen inside the tilt-tube. How did you get yours out?
Thanks.
jeffreyi
answer at my post Chrysler Force..."Steering problem"
D
DJ
Guest
Right here on iboats. Great prices, great service. Use your old cable as a guide for the length. See link below.
http://www.iboats.com/Boat_Steering....217122--view_id.217122--search_type.category
You're better off, in my opinion, replacing the whole kit (helm, cable). I prefer the rotary systems. They seem to be smoother and take up a lot less room under the dash.
As for a stuck cable, the word is patience. Use heat cautiously and lots of pentrating oil. You will have to pound it out GENTLY with a drift rod.
Jeffreyi
What's a drift rod and where can I get one?
D
DJ
Guest
A "drift" is just a very dull punch. Basically a soft steel or brass rod that is slightly smaller in diameter than what you are trying to drive out.
