1000dollabill
Thread starter- Joined
- Aug 5, 2007
- 20
I need help before I send this boat to the bottom of the lake.
1989 Ski Centurion Falcon 20
5.8L Indmar
Brand New:
Holley 80319-1 carb
coil
plugs
wires
distributor
f/w separator
fuel filter on pump
Checked:
135 psi compression on all cylinders
fuel pick-up clean
tank vent clean
all inline filters/screens clean
no fuel in fuel pump rupture line.
pulled anti siphon very difficult to blow through. Attempted to clean with an awl, very easy to blow through now.
all connections clean, all grounds good.
pulled fuel pump no wear or wobble present.
Prop in new condition
firing order checked 35 times
all plugs a nice tan color
no water in oil
had prestolite electronic conversion but put points, condenser, and ballast resistor back in. Points set to .018, plugs set at .035 (autolite 24's), timing set to 10 btdc at 600 rpms.
Idles great, runs great up to around 2900. anything above hesitates and backfires through carb. Will not rev over 3000 under load. original coil would not let it rev over 2500rpms. engine temp is consistent at 160.
the weird part is last outing putting around the lake for about an hour the backfire started occurring at around 2500 rpms under acceleration. maybe an overheated ignition module or coil. Also after putting the points back in there is a noticable popping in the exhaust at 3,000 rpms and above while out of the water running on the hose and bucket.
my best guess now is the fuel pump because it will rev to the moon without load. can a mechanical pump become weak? all gas is new 92 octane (four tanks run through it below 3000 rpms.) could my popping in the exhaust be the dwell incorrect?
Please help me,
Bill
5.8L Indmar
Brand New:
Holley 80319-1 carb
coil
plugs
wires
distributor
f/w separator
fuel filter on pump
Checked:
fuel pick-up clean
tank vent clean
no water in oil
Please help me,
Bill
