1972 evinrude 6 hp
sea b
Having problems with bogging down. Changed the fuel pump the water pump the spark plugs and cleaned the carb. She runs much better for longer but won't stay at full throttle after running wide open for 10 minutes. What else could it be? Please help:eek:
reload
Re: 1972 evinrude 6 hp
Sounds like it is a fuel delivery problem. I would check fuel lines and bulb for clogs. Check gasket between fuel pump and engine. Check float for proper drop.
sea b
how do I check the float for proper drop? When the carb was out I made sure it was level. (I guess) Could this also be a result from the engine being overheated? I have read that this is a pretty good engine and pretty easy to work on? Thanks for repling so fast.
reload
You mean overheating in the past or do you mean now?
Overheating now would cause this and everytime you try you are doing more damage. What you are experiencing is the engine starting to gull.
I have never heard of overheating in the past causing a problem that would only show up after ten minutes running. How many times have you done this? It only takes once to do the damage. It is unlikely if you overheat it the some damage will not occur.
It might be a coil heating up also.
Float drop is how far the float drops when the level falls, it regulates how much fuel can flow.
sea b
the water pump went out while we were running it and we didn't know. Also, it will cut out and then kick back up in spurts when the throttle is opened up.
reload
So when did it overheat and when did the problem start?
reload
No matter what I would check compression. I think you are going to find a very marginal cylinder.
reload
How does a five star thread rating get put on a thread?
sea b
They have a little survey on the end on rating so I rated your response with 5 stars? I don't know I just started this.
Well the history is we just bought this boat. Put it in the water because of course it ran fine at home. First outing it wouldn't stay idling. So we cleaned the carb and rebuilt it. Second outing fuel pump and third impellor because it over heated and shut off. How can I check compression and what does a marginal cyl mean? :confused:
HighTrim
T check compression you will need a basic screw in type found at most auto parts stores. What he meant by marginal is off a bit or below average i assume. You want within 10 percent of each other and depending on your motor and age, usually over 100 psi per cylinder. Also might be a good idea to re torque all your bolts on the motor since the heats tends to loosen them.
(Compression & Spark Test)
(J. Reeves)
1st - Regardless of what problem one might encounter, always start with the basic troubleshooting procedure. Check the compression which should be in the range of 100+ psi (somewhat less on the smaller hp engines) and even on all cylinders.
2nd - With the spark plugs removed, rig up some type of spark tester whereas you can set a gap to be jumped. On magneto ignition systems.... and also the Battery Capacitance Ignition system OMC engines from 1968 to 1972, set the gap to 1/4". On the solid state OMC ignition systems from 1973 to the present, set the gap to 7/16". The spark should jump the gap with a strong blue lightning like flame..... a real strong blue snap!
If there was no spark, on engines from 1973 up, disconnect the RED main electrical plug at the engine. Remove the s/plugs. crank the engine via the starter solenoid (jumper bat term to small 3/8" term nut, not the ground nut) and observe spark. If spark is now okay as stated above, the usual cause is a shorted ignition switch.
If the above checks out as it should, and the engine dies out when throttle is applied or won't idle, it is usually due to one or both of two things. The carburetors are fouled, in which case the cure would be to remove, clean, and rebuild them..... or the timer base under the flywheel is sticking which would result in a retarded spark. If the engine will not fire/start at all even though you have the proper spark and compression, it's usually due to fouled carburetors.
To check the timer base for sticking (Engine Not Running), spin the prop to align the shifter dog with forward gear and while doing so, put the engine into forward gear. Now, while watching the timer base, slowly apply throttle clear up to full throttle. The timer base should move smoothly all the way up against the black rubber cap that is atached to the end of the full advance spark setting screw. If the timer base sticks, find out why and correct that problem.
Usually any sticking of the timer base is caused by one of the four retaining clamps being slightly too tight. Putting a very thin washer under the clamp cures that problem. Some boaters use a thin screwdriver to bend the clamp upwards slightly but I prefer the thin washer. The sticking can also be caused by having a faulty stator start to melt down, resulting in a sticky substance dripping down on the timer base nylon retaining ring.
HighTrim
Sorry and to check compression, bring your motor to operating temp, take out all your plugs, screw in the tester into one of the holes, get someone to turn your motor over, or pull start it about 4 to 5 times or until the tester reaches its limit, record reading, then follow through with remaining cylinders.
sea b
So if the compression is off what can be done? This is a 1972 fisherman. When it is running it sounds like a sewing machine it sounds great.
HighTrim
I wouldnt worry about blown bridges until you reach them, you may not have a problem. Try the test, easily done by the way and should only take about 10 mins, then post your results and the guys will help you from there.
sea b
Thank you for your replies! I just don,t undestand why it only starts acting up
when the boat is on plane for about 4 minutes or so then it starts sputuring
like it is losing spark but I have checked the spark at home and at the ramp and it was fine ,but I have not been able to catch it when it acts up.
I,am wondering if there could be a problem with lack of oxygen under the cover?? Would this cause my problem,there is only 1 vent hole under the carb and it about the diameter of a pencil. Could the motor be choking it,s
self out????
HighTrim
thats easily checked by running the motor with the cowl off. And did you ever check the bulb and fuel lines for clogs?? If you pump the bulb when its dying will it pick up?? The motor doesnt overheat at all does it?
sea b
I have at home ,but wide open on the water? I,m afraid that water or bugs getting in the carb not to mention salt water.Do you think this is a possibility though??
sea b
The bulb and lines are newer but they are from wal-mart
Scaaty
Make sure the tank is well vented if not mentioned
sea b
Taking the boat back out to see if we have solved the problem. We are buying a new bulb and lines from the marina at the ramp. We will try taking the cowl off and let everyone know what happens from there thanks!:cool:
sea b
we took the spark plug wire off one cyl at a time and found out that the motor is only gettin spark to one cyl. We also did the spark plug test. should we change the points and the magneto?
Do you know what to set the points at? Will this be a sure fix for this type of problem?
