Torque specs
Thumbtack
merc 350 5.7L 1995. serial number OF072582
what are the torque specs for not the oil baffle nuts but the studs that the nuts screw to, also what are those studs called?
Re: Torque specs
I'm assuming that you're looking at the Bottom of the motor,.......
Those would be the Main Bearing Bolts........
The Windage Tray is then nutted to the shorter studs......
I don't have that # handy,....
But searching for the Main Bearing Bolt Torque should find it Quickly.........
Thumbtack
Re: Torque specs
thank you, that is exactly what i am looking for. I think it should be 80' lbs. thanks again
180shabah
Re: Torque specs
Main Bearing caps on the 4.3 (V8's may be different, but I doubt it) get torqued to 75 lb./ft. according to the FSM.
Not sure about the torque values for the windage tray.
