omc starting problems
fubar 81
So here's what I've got, a 1988 sea swirl tahoe with a omc 3 liter. I have power to the ignition switch but none of the accesories or guages move when the key is on. A new ignition switch was put on with the same resuts. The engine won't crank at all nor will the outdrive move up or down. when the boat was first trailerd home the engine cranked over then when I moved the throttle to give it some gas everything quit. So I by-passed the nuetral safety switch (or what ever its called) and still nothing. Any ideas would be greatly appreciated thank you.
marunr
Re: omc starting problems
Is your safety lanyard still connected? Is your battery in good shape? Try cleaning all of the connections to "like new".
You did have water hooked up when you started it didn't you?
fubar 81
This boat doesn't have a safety lanyard, and yes the battery is in good shape it reads over 12 volts and I cleaned the terminals. The water isn't hooked up right now just because it won't even turn over.
Liberator 6
This may help...
fubar 81
Thanks for the help guys hope fully it will clear things up.
