jgbutler1956
- Aug 2, 2007
- 16
I just bought a Mako with a Johnson 140 thrown in. I can crank, but doesn't run great. Compression is 80,90,75,90. (top left, bottom left, top right, bottom right) I increased numbers from putting Yamaha ring free in gas. (was lower on all four) Runs for a little while with pee hole running water out, but engine gets hot. (can't touch for 2 long) Was supposed to have been re-built.. I can see someone took of heads and put gaskets and sealant back on. I run it for a little while then shut it off.. I have looked at the plugs and they are still wet with black wet substance. (is this the carbon?)
Do I
1. Replace the impeller
2. Take off head and inspect pistons. Replace gaskets with or without sealant?
3. Get another motor?
I am new to outboards, but am a fast learner. Would appreciate info on where to get the parts and the part numbers.
I have a manual ordered, but not here yet.
Thanks
Beware the lollipop of mediocracy, one lick and you will suck for life
Do I
Thanks
