etransfer
Thread starter- Joined
- Jul 29, 2007
- 63
I have a 2008 Tahoe Q6 and the swim platform is in the way to install the SX trim tabs.
It's 2800 lbs with the V6 220 hp Alpha one.
The attached picture isn't my boat it's someone elses here on the forum but it shows the same angle as my boat. The red lines show the angles of my boat with the swim platform in the way and the yellow shows the only way I can install it to get around the swim platform.
I can get them installed if I move the setting all the way out like in the yellow line in the picture which is the #5 setting (strongest).
My questions are these?
1. Since this is the strongest setting should I still install them at 25 degrees
or 20 using the SX9510-80 ?
2. Since I won't be able to adjust these once installed and it'l be at the max setting should I just install the 60 Lb at 20 or 25 degrees ?
